Highlighted
Beginner
Conference with standalone SX10 and MCU 5310
Is it possible for a few SX10 to dial IP address MCU for join video conference? Both of devices are standalone (not register to CUCM or VCS). If that's possible, Can SX10 choose particular conference rooms which has been created before? From what I know, usually each conference room has different extension that can be dialed and with my scenario, all SX10 can only dial IP address since there is no SIP registrar.
4 REPLIES 4
Highlighted
Engager
I do not have a SX10 which I
I do not have a SX10 which I can access right now, but I tried it with a SX20 with disabled h323
and I was able to dial in to a conference dialing a sip:number@domain address.
So you can test it, but the recommendation shall be to use a call control which supports your network
(it makes it more complicated if NAT is involved).
Highlighted
Beginner
I haven't got MCU yet, that's
I haven't got MCU yet, that's why I can't test it. From dial pattern that you specified above, do you mean "domain address" as IP address of MCU?
Highlighted
Beginner
I think I understand what you
I think I understand what you're talking about.  A lot of my customers still dial IP address only.  First of all, I heard you need to change the configuration of the call control to direct, then you can dial IP addresses.  If you dial the IP address of the MCU, you should see the blue screen that says "Please enter the conference ID followed by the # sign"?  I don't have an SX10...yet... but I'd imagine it works just like an SX20 where you enter the numberic ID assigned to the conference on the MCU, then enter the # sign.  I'm curious if the SX10 allows selecting the conference via Far End Camera Control, like the SX20.
Good Luck!
Highlighted
Beginner
Hi Ferdi, I tested for
Hi Ferdi,
I tested for standalone SX10 ,I was able to dial other location .
we need to make some changes in configuration.....  in SIP url field type dummy_extention@IP_address...
for example 101@IP_address
whenever i dial out to any location i need to follow the same pattern extention@Ip and this is beacause SX10 is SIP only system.....
