Connecting Polycom HDX ceiling microphone to Cisco SX80
majeed002
I have a requirement where I have to connect the Polycom HDX ceiling microphone to Cisco SX80.  To make the connection, I need a converter to convert RJ45 to Euroblock to connect it to SX80.  Will it work directly.  Has some one tried it before.  I did see in some supportforums threads that connecting polycom ceiling microphone to Cisco codec will work.  But no details on whether a simple converter is good enough.
Please advise.
Thanks.
Amlesh Sengar
Hi Majeed,
I believe a converter from RJ45 to Euroblock will work.
Cisco Telepresence Ceiling Microphone are also connected to SX80 using same converter.
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/microphone/installation_guide/ceiling-microphone-installation-guide.pdf
Amlesh
