10-27-2010 04:01 AM - edited 03-17-2019 10:08 PM
System shows LCD is not detected via serial. Serial cable connection is according to procedure. What else can I miss ?
Solved! Go to Solution.
10-27-2010 09:10 AM
Just to be sure, did you activate LCD in CUCM?
What is the version of your CUCM?
Samuel
10-27-2010 09:10 AM
Samuel
10-27-2010 09:43 AM
Why CUCM ? But LCD is connected direct to ACU & indirect t
o Primary Codec.
10-27-2010 09:47 AM
Yes but you need to activate LCD in the CUCM in the CTS-3010 device that you create.
10-27-2010 10:00 AM
OK. I will check with person in charge as I dont't have CUCM access.
What about CTSAdmin ? Any activation/ configuration ?
10-27-2010 10:06 AM
No
