06-08-2012 12:53 AM - edited 03-17-2019 11:17 PM
I saw an information about interoperability for CTS series and Codian MCU 4500. It says CTS supports Codian MCU 4500. Actually I am surprised. I used to know it is possible to make a multipoint conference with CTSes on only TPS server or CTMS. Could you please clarify this issue? Does the CTS support to connect the Codian 4500 MCU? If so what are the limitations?
Best regards,
Tufan
06-08-2012 01:09 AM
CTS do support standard H.264 video capability from software 1.7.4 release.
CTS-4500 series MCU connection use this standard H.264 capability not TIP.
Please note version 1.7.4 is early phase release for this interop and has improved interop level in newer version.
More detail information is available on CTS release note and interop document.
06-08-2012 02:07 AM
As the MCU 4500 series does not support TIP there are several limitations, including;
- no support for multi-screen systems, so e.g. CTS3000 will connect with one screen only
- no support for Roster list
- no support for locking conference
- lower maximum resolution support than in TIP mode
