1234
edgar.feliz
Beginner
CUBE Enterprise on ASR1002
I am trying to configure CUBE on a ASR 1002 to support Telepresence and some of the commands I see for CUBE enterprise are not taking on the ASR.
Is CUBE Enterprise supported on ARS1002? If so does anyone have a sample configuration.
Edgar
1 REPLY 1
hdewulf
Beginner
I think the software which is installed on your ASR isn't part for Telepresence support.Can you first check this out.
You need to have RLS7 CUBE(Ent) on ASR will support Telepresense.
http://www.cisco.com/en/US/docs/ios/ios_xe/voice_cube_-_ent/configuration/guide/vb_roadmap_xe_ps11174_TSD_Products_Configuration_Guide_Chapter.html
     SIP Video Support for Telepresence Calls
     Cisco IOS XERelease 3.1S
Check also the Telepresence release note : http://www.cisco.com/en/US/docs/telepresence/cts_admin/1_7/release/notes/cts_1_7_release_notes.html
Create
Recognize Your Peers
Content for Community-Ad
