10-30-2012 03:27 AM - edited 03-18-2019 12:03 AM
Hello everyone,
in our Videoinfrastructure their is a little problem with cisco jabber client register on the CUCM to our MCU.
The MCU is registered on the VCS.
If I do a SIP call from my Cisco Jabber Client the call failed. I'm calling the Number 4925488XXX. The callingparty is the 25203232.
In the CUCM there is a Routepattern which translate the number to "Called Party Number = 8099" (this is the SIP Trunk to the VCS).
Called Party Transformations:
Called Party Mask = 8XXX
Discard Digits Instruction = None
Prefix =
Called Number = 8099
In the VCS their is a transform for the called Number 8099.
The MCU is registerd with 99@xxxx.xxx on the VCS - this is the auto attandant.
In the Cisco Jabber client I never receive video or sound of the MCU AA - it's look like that the call isn't connect.
If I spent a look in the VCS I see the call as active and connected.
Also I traced the call from the VCS in debug mode.
SIPMSG:
|SIP/2.0 180 Ringing
Via: SIP/2.0/TLS CUCM IP SIP ;branch=z9hG4bK10ea4511f7965;received=CUCM;ingress-zone=CUCMUC
Call-ID: b6958600-8a19125-10424-6083ca0a@10.202.131.96
CSeq: 101 INVITE
Contact: <sip:99@MCU;gr=urn:uuid:c4a744d7-5975-52db-b21c-8c519fbab06e>;isfocus
From: "Stefan Walter" <sip:25203232@10.202.131.96>;tag=252394~c75f2de1-fd7b-43c2-8bd0-6b72860c9048-46890229
To: <sip:8099@VCS IP>;tag=11B05829C2080000
Record-Route: <sip:proxy-call-id=b7e41e30-1f71-11e2-a211-0010f32081f0@VCS SIP;transport=tls;lr>
User-Agent: Codian MCU 4505 v4.3 (2.18)
Content-Length: 0
2012-10-26T15:33:25+02:00 DDUCP001 tvcs: UTCTime="2012-10-26 13:33:25,230" Module="network.sip" Level="INFO": Src-ip="CUCM IP" Src-port="39813" Detail="Receive Request Method=CANCEL, Request-URI=sip:8099@VCS IP, Call-ID=b6958600-8a19125-10424-6083ca0a@CUCM IP"
2012-10-26T15:33:25+02:00 DDUCP001 tvcs: UTCTime="2012-10-26 13:33:25,230" Module="network.sip" Level="DEBUG": Src-ip="CUCM IP" Src-port="39813"
SIPMSG:
|CANCEL sip:8099@10.202.80.21:5061 SIP/2.0
Via: SIP/2.0/TLS CUCM IP SIP ;branch=z9hG4bK10ea4511f7965;received=10.202.131.96
Call-ID: b6958600-8a19125-10424-6083ca0a@CUCM IP
CSeq: 101 CANCEL
From: "Stefan Walter" <sip:25203232@CUCM IP>;tag=252394~c75f2de1-fd7b-43c2-8bd0-6b72860c9048-46890229
Max-Forwards: 70
Date: Fri, 26 Oct 2012 13:33:25 GMT
Reason: Q.850 ;cause=3
Content-Length: 0
Reason: Q.850 ;cause=3 ;text="No route to destination"
You have any hint for me where I can troubleshoot further ? It is an MCU issue or CUCM or VCS ?
bye
Stefan
Solved! Go to Solution.
10-30-2012 06:58 AM
Hi Stefan. I'd probably run an SDI Trace on the CUCM as well. Seems the cancel is coming from CUCM side and ending the call. To verify that your possibly running into: CSCty07061, I would run the SDI trace and see after it receives 180 Ringing from VCS if it tries to do a DNS Query for @mcu.
Entries may look like:
|2,100,63,1.3508793^10.52.36.15^*
11:20:09.377 |//SIP/SIPDns(2,72,1)/wait_SdlDnsSrvRecordRsp: Received SdlDnsSrvRecordRsp ReqCode is -1|0,0,0,0.0^*^*
11:20:09.377 |//SIP/SIPDns(2,72,1)/copyRecordRspToRecordReq: Retry SRV query as an 1 query|0,0,0,0.0^*^*
11:20:09.377 |//SIP/SIPDns(2,72,1)/wait_SdlDnsSrvRecordRsp: (DNS A or AAAA query called as SRV query Fail)hostname=mcu
If this is what your running into, fake address to resolve @mcu would be needed for the call to proceed. I'm basing this off an assumtion here, but can't actually guarantee this is what your running into. But check the SDI trace AFTER the 180 ringing and see.
Hope this helps.
VR
Patrick
10-30-2012 10:05 AM
Hi Stefan. Need to resolve domain.domain.de. CUCM tries to resolve the address in contact header and it fails hence the bug. The DNS server being used by CUCM, create an A record for domain.domain.de and it can resolve to any IP address. It doesnt matter where it resolves to as long as it passes to proceed the call.
Hope this helps.
VR
Patrick.
Sent from Cisco Technical Support Android App
10-30-2012 06:58 AM
Hope this helps.
VR
Patrick
10-30-2012 08:49 AM
Hi Pettit,
thanks for your reply.
I collected the SDI Traces from the CUCM and see this output:
SIP/2.0 180 Ringing
Via: SIP/2.0/TCP 10.137.163.69:51340;branch=z9hG4bK3554c54f
From: "Stefan Walter" <25203206>;tag=d4a02a88c49b40133af4b1ab-15462b0d25203206>
To: <4925488099>;tag=296200~c75f2de1-fd7b-43c2-8bd0-6b72860c9048-468906604925488099>
Date: Mon, 29 Oct 2012 14:55:56 GMT
Call-ID: d4a02a88-c49b003e-7b07060d-5361483f@IP
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Allow-Events: presence
Call-Info:
Send-Info: conference, x-cisco-conference
Remote-Party-ID: <8099>;party=called;screen=yes;privacy=off8099>
Contact: <4925488099>;isfocus4925488099>
Content-Length: 0
|2,100,63,1.301260^10.202.80.21^*
15:55:57.059 |//SIP/SIPDns(2,72,1)/wait_SdlDnsSrvRecordRsp: Received SdlDnsSrvRecordRsp ReqCode is -1|0,0,0,0.0^*^*
15:55:57.059 |//SIP/SIPDns(2,72,1)/copyRecordRspToRecordReq: Retry SRV query as an 1 query|0,0,0,0.0^*^*
15:55:57.059 |//SIP/SIPDns(2,72,1)/wait_SdlDnsSrvRecordRsp: (DNS A or AAAA query called as SRV query Fail):hostname=domain.domain.de, ReqType=1,serversused=0
|0,0,0,0.0^*^*
Seems so that we are running in
Can you explain me what to you mean with fake address to resolve the @mcu
BR
Stefan
10-30-2012 10:05 AM
Hope this helps.
VR
Patrick.
10-30-2012 10:53 AM
Hi Patrick,
I'm understandig that the CUCM (the DNS) will resolve the domain.domain.de.
Tommorow I'll contact our DNS Admin to fixed it.
Think that I create a A record to the IP-Adresse of our VCS. Think that will fixed the problem.
It's right that with SW 9.0 XXXX the bug is fixed ? Can we also upgrade the CUCM to 9.0 ???
Thanks a lot for your help!
10-30-2012 11:48 AM
Hi Stefan. Sure. I do believe upgrading to CUCM 9 should fix this. Or, when the address in the Contact Header is looked up, all you need is CUCM to resolve it so it can complete, cause if it can't, the call will fail. So maybe pointing domain.domain.de to the IP of the VCS and that should be ok. If calls still fail, will need to see another trace to see whats going on.
VR
Patrick
