10-03-2017 03:16 AM - edited 03-18-2019 01:30 PM
what type of device we must create on CUCM to register a Cisco Spark Room Kit.
Nuno
Solved! Go to Solution.
10-03-2017 07:28 AM
Hi Nuno,
The device type must be Cisco Spark Room Kit, however you must make sure to have the correct device pack installed on a supported CUCM version.
Please see the compatibility matrix for details
10-03-2017 07:28 AM
Hi Nuno,
10-03-2017 07:33 AM
Hi Zoltan,
thanks for youy answer.
Do you know if there is a device package for version 9?
Once again, thanks for the support.
10-03-2017 07:40 AM
I believe minimum is 9.1.2something
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvd22818
And the dev pack for 9.1.2 is (minimum): cmterm-devicepack9.1.2.17151-1.cop.sgn
02-12-2018 07:54 AM
what device pack do we need to install on CUCM 11.5 to support all the room kit systems? please share the file path, thanks.
02-12-2018 08:04 AM
06-28-2018 11:24 AM
i'm running 11.5.1, and there is no "Cisco Spark Room Kit", just "Cisco Spark Remote Device"
06-28-2018 11:28 AM
Have you installed the device pack to add that new device type?
