07-10-2019 11:28 AM
Hi, everyone.
Is there any option to define the ports that will be used by Audio, Video, and Content in Cisco CMS and Cisco SX / C series Endpoints?
We have the need to define port = QoS value. For example:
For your answer, Thanks in advanced.
Solved! Go to Solution.
07-10-2019 07:05 PM
I do not belive that you can fix the ports like that. The endpoints can certainly tag their different types of traffic with the right QoS markings though which you can then trust with your network infrastructure.
See the Setup > Configuration > Network > QoS part of the web interface, or for futher info, the QoS settings on pages 133 - 135 of the SX20 Admin Guide.
Please remember to mark helpful responses and to set your question as answered if appropriate.
07-11-2019 05:57 AM
Thanks for your answer.
I know, and I preffer the way you say.
I looked for in the documentation and just find the way you said. I think it's a better way.
07-10-2019 07:05 PM
07-11-2019 05:57 AM
07-11-2019 04:16 PM
If you do it consistently with the Enterprose QoS Solution Reference Network Design Guide it will be a much better solution moving forwards too as it's then based on best practices and will be a lot more supportable.
