Beginner
Dial-Peers and Incoming Caller-ID
I am trying to setup my first CME VOIP Lab and I am having some trouble.  I can dial local #s and national #s, but toll free numbers aren't going through.
Also when I get an incoming call the Caller-ID doesn't show up, the 7960 just says "External Number"
I tried the "caller-id enable" under the voice-port 1/1/0 (which is my FXO card) and I get this:
CallManager(config-voiceport)#caller-id enable
% Invalid input detected at '^' marker.
Any ideas?
Here is my config:
Current configuration : 6606 bytes
! Last configuration change at 01:26:24 pst Fri Jun 7 2013
! NVRAM config last updated at 01:12:02 pst Fri Jun 7 2013
version 12.4
hostname CallManager
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
clock timezone pst -8
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip dhcp use vrf connected
ip dhcp pool VOICE/DATA
   network 10.0.50.0 255.255.255.0
   option 150 ip 10.0.50.1
   default-router 10.0.50.1
trunk group  OUT
voice service voip
dtmf-interworking rtp-nte
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
h225 timeout tcp establish 3
h225 timeout setup 3
voice class cause-code 1
no-circuit
voice translation-rule 1
rule 1 /^702586\(1...\)$/ /\1/
voice translation-profile DID
translate called 1
crypto pki trustpoint TP-self-signed-2215009052
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2215009052
revocation-check none
rsakeypair TP-self-signed-2215009052
crypto pki certificate chain TP-self-signed-2215009052
certificate self-signed 01
  30820243 308201AC A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32323135 30303930 3532301E 170D3133 30363037 30343133
  34385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 32313530
  30393035 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B100 E333437B 44D0EC60 8FADE1A0 89D3ADBC CDE13BD5 623B5205 75493AFB
  C0D8BF0F 8D9129F1 5DE54189 C182498F 531FE400 AEA816C6 F6A7FCF0 447636BB
  79B90C31 51B2879A 84489D5D 889DA761 835E8501 C9D86C3F 453214A2 A8EEA53C
  C0244A31 703DA1F7 CA61AAAE A9BD3AED A1910AB4 98F24607 18208372 6E12F2B1
  85450203 010001A3 6B306930 0F060355 1D130101 FF040530 030101FF 30160603
  551D1104 0F300D82 0B43616C 6C4D616E 61676572 301F0603 551D2304 18301680
  14490111 E89DCDAD EBB061C6 84597CC0 58E8CFCE 30301D06 03551D0E 04160414
  490111E8 9DCDADEB B061C684 597CC058 E8CFCE30 300D0609 2A864886 F70D0101
  04050003 8181000B 6829EF4F 26D5A8A8 BD03CFC2 810A2ED2 FDDBFAB3 097B4074
  4A24959C 6564863D 9B7C6B67 E0C817D8 0CC796C2 945DA12B BA30D9A1 9EA6FB70
  BB2E2653 D88D07A2 A530EE03 D9E72CB3 6B267C9A 0E130BF1 D6EAACC5 9EB375DF
  2BF2AB25 F03C3FCA C5611B0B 94BACA6B 12238396 D885D4D8 492B75BD 4B40073F
  27CF0FB5 D562B9
        quit
username woodjl password 0 henry999 privilege 15
username woodjl1650 password 0 henry999 privilege 15
archive
log config
  hidekeys
interface FastEthernet0/0
ip address 10.0.50.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
encapsulation frame-relay
no fair-queue
interface Serial0/0.31 point-to-point
ip address 10.1.12.3 255.255.255.0
snmp trap link-status
frame-relay interface-dlci 301
interface FastEthernet0/1
ip address 20.0.24.2 255.255.255.0
duplex auto
speed auto
router ospf 1
log-adjacency-changes
network 10.0.10.0 0.0.0.15 area 2
network 20.0.24.0 0.0.0.255 area 4
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.0.10.3
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip http path flash:gui
tftp-server flash:P00308000400.bin
tftp-server flash:P00308000400.loads
tftp-server flash:P00308000400.sb2
tftp-server flash:P00308000400.sbn
control-plane
voice-port 1/0/0
ring cadence pattern01
cptone GB
description Fax_Machine
caller-id enable
voice-port 1/0/1
voice-port 1/1/0
trunk-group OUT
no battery-reversal
cptone GB
connection plar opx 1001
description Office Line
voice-port 1/1/1
no battery-reversal
cptone GB
connection plar opx 1002
description Home Line
dial-peer voice 1004 pots
incoming called-number .
direct-inward-dial
dial-peer voice 200 voip
destination-pattern 1...
session target ipv4:10.0.50.1
dial-peer voice 1 pots
preference 1
destination-pattern 91..........
port 1/1/0
forward-digits 11
prefix 1
dial-peer voice 2001 voip
destination-pattern 1001
codec g711ulaw
dial-peer voice 2002 voip
destination-pattern 1002
codec g711ulaw
dial-peer voice 1001 pots
trunkgroup OUT
description Long Distance
forward-digits all
dial-peer voice 1002 pots
trunkgroup OUT
description Local Calls
destination-pattern .T
forward-digits 7
dial-peer voice 80 pots
trunkgroup OUT
description Toll Free Dial-Peer
destination-pattern 18[00,55,66,77,88][2-9]......
forward-digits 11
prefix 1
gatekeeper
shutdown
telephony-service
load 7960-7940 P00308000400
max-ephones 24
max-dn 48
ip source-address 10.0.50.1 port 2000
timeouts interdigit 2
time-format 24
max-conferences 4 gain -6
web admin system name woodjl1650 secret 5 $1$j3F0$ZJyBANEPW2SAmJp8OUcXL.
dn-webedit
time-webedit
transfer-system full-consult
directory entry 1 7027787551 name Home
directory entry 2 9137580443 name Steve & Teresa Wood Home
directory entry 3 9136831205 name Teresa Wood Cell
directory entry 4 9136833052 name Steve Wood Cell
create cnf-files version-stamp 7960 Mar 23 2013 00:14:46
ephone-dn  1
number 1001
label Lab
description Lab
name Lab
hold-alert 30 originator
ephone-dn  2
number 1002
label Office
description Office
name Office
ephone  1
device-security-mode none
mac-address 0013.80DF.7F34
speed-dial 1 7024011492 label "Jonathan Cell"
speed-dial 2 7024011526 label "Katie Cell"
speed-dial 3 7024041362 label "Ops Desk"
speed-dial 4 1001 label "Cisco Lab"
type 7960
button  1:1
ephone  2
mac-address 0011.20BA.F7B8
speed-dial 4 1002 label "Home Office"
type 7960
button  1:2
ephone-hunt 1 peer
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
login
ntp server 64.250.229.100
end
Everyone's tags (4)
1 REPLY 1
Highlighted
Hall of Fame Master
Try
dial-peer voice 80
forward-digits all
no prefix 1
