Documentation for Cisco Tele presence Infrastructure
Not applicable
Hi Everybody ,
                          We have a Video Conferencing network without any documentation that I need to streamline . Any suggestion to what kind of documentation I can start working on . If somebody has any templates that would be highly appreciated . We have the following :-
1- Cisco Telepresence Codec C90               Qty=12
2- Cisco Telepresence Codec C60               Qty=12
3- Cisco Telepresenc   Codec C40               Qty=6
4- Cisco VCS Cluster                                 1 Cluster ( 2 VCS units)
5- Cisco TCS Cluster                                  2 Clusters ( 4 TCS Units)
6- External Storage for the TCS
Best regards
Aziz ur Rehman
5 Replies 5
deamanga
Hi Aziz
You need to connect to the Cisco site or search in Google  to upload any user or admin guide related to your equipment’s everything is available online.
regards
Dean
The user documentation for the TelePresence products is found here: www.cisco.com/go/telepresence/docs
The user documentation for the TelePresence C Series is found here: www.cisco.com/go/cseries-docs
Margareth Wennersteen
Not applicable
Hi Guys ,
                The thing is the VC network is already configured . I am looking for  an "As-Built" template in which i can fill in all the configuration done on the Codecs and infrastructure equipment . I hope that clears things out a bit ..
Best Regards
Aziz ur Rehman
Hi Aziz, You may want to consider deploying Cisco TelePresence Management Suite (TMS) in your N/W to manage the devices you have. Pls refer to the following URL http://www.cisco.com/en/US/products/ps11338/tsd_products_support_series_home.html for TMS documents.
BR,
Mahesh Adithiyha
Adam Wamsley
Hello Aziz,
If you do not have a TMS, for the codecs and VCS you can log into the CLI and do an xconfiguration. The xconfiguration will give you a list of all the configurations you can do for that codec or VCS. You can put this into notepad and edit the settings to whatever you desire (most likely the generic settings you'll want to put on each codec). This can then be pasted into the CLI of each codec and VCS (remove the ".*" before copying over). After this is done you can then go in and add any specific settings you want for each codec such as the IP address/URI/etc. This is essentially a generic way of doing it without a TMS.
You can refer to the API guide for what the xconfiguration commands are.
http://www.cisco.com/en/US/docs/telepresence/endpoint/codec-c-series/tc5/api_reference_guide/codec_c60-c40_api_reference_guide_tc51.pdf
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/admin_guide/Cisco_VCS_Command_Reference_X6.pdf
Adam
