Dual Monitor on C90 Not displaying presentation
rmcconnell
I'm hoping someone has done this:
I want to send Video and Content from an endpoint to a C90 at the remote end. There is no bridge involved.  I would like one of the displays to have the remote end presenter, and the other display to have the Content (Presentation from presenters PC).
I have fired up TConsole on the receiving end, but it seems to only allow me to display local content, not the remote end content.
Any ideas??
thanks
Rob
Patrick Sparkman
You need to set "Video Output HDMI [1,3] MonitorRole" on the endpoints, see the C90 Admin Guide for more details.  Refer to "Video Monitors" to see what role each monitor will take depending on the number of monitors being used.
You might also want to configure what monitor selfview will appear on, you can do that with "Video SelfviewDefault OnMonitorRole" and you'll also want to set "Video SelfviewDefault FullscreenMode" if you do configure selfview.  Or else selfview will appear on the same monitor as the far-end.
I will give it a go
regards
Rob
