07-23-2016 02:03 AM - edited 03-18-2019 06:10 AM
Dear Team,
Please advise if One drive, Skype for business, Outlook and office 365 are supported on DX80.
It allows downloading the application from Play store but the application is not starting.
BR
08-02-2016 12:20 PM
If the applications fail to start, than it's probably safe to say they aren't supported. I haven't seen any list of supported/non-supported applications, so I can't say for sure.
08-03-2016 10:27 PM
Hi Muhammad,
Please be informed that the DX80 can run any compliant Android application.
However, Cisco does not support third-party applications directly. You should consult the application vendor and/or developer if you need application support.
Please refer to the Cisco DX80 Data Sheet -> Application Features:
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/desktop-collaboration-experience-dx600-series/datasheet-c78-731879.html
Shefali Sharma
