Edge 85 - can I do dual monitor?
Shy Solenko
Some nostalgic question:)
We have edge 85 single monitor that works greats for several years now.
And we want to upgrade it to Dual monitor.
Is it possible?
Do I need option key? Can I buy it from Cisco? (this system is not under production for several years...)
Thanks for your answers.
Shy
Patrick Sparkman
No option key is required for the MXP endpoints to support dual monitors, simply connect the the monitor to an available output and configure the codec, here is the MXP F9 Admin Guide for reference.
It's very helpful
