AMA-CUCM Troubleshooting: Best Practices for Reading Trace Files
387
Highlighted
Beginner
Edge 95 Extension Microphones
I'm looking for guidance with extension microphones and the required adapters/cabling for them.
I have an Edge 95 MXP installed in room, the audio quality is poor hence the need for extension microphones.
Thank you in advance
1 REPLY 1
VIP Advisor
The Edge 95 MXP uses standard balanced XLR conenctors for the microphones.  You can extend the existing cables with XLR extensions if you need to get the microphones closer to where they're requried.
Adusting the gain settings in the Audio menu may also help you tuning the room you have the unit in.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Content for Community-Ad
August's Community Spotlight Awards
