10-15-2012 11:16 AM - edited 03-17-2019 11:58 PM
I have recently come into an operation using a legacy Tandberg Edge 95. The firmware on the unit, from what I can tell has never been updated. It is currently running F6.0. I have downloaded the F9.0.2 pkg but I am unfamiliar with this procedure. Can anyone assist or point me to an insturctional site on updating this unit?
Solved! Go to Solution.
10-15-2012 01:38 PM
upgrade is covered from page 141 in this document -
You'll need a F9 release key too.
10-15-2012 01:38 PM
10-16-2012 06:46 AM
Where may I obtain that? From Cisco?
10-16-2012 07:08 AM
yes from Cisco, try licensing@cisco.com or any account manager you may have.
04-20-2015 09:06 PM
Hi Gubadman :
Where can I find release key ,
I want to upgrade my TANDBERG Edge 95MXP
from F9.1.2 NTSC to s50001f9_3_3
Felix Lee
04-20-2015 09:33 PM
You shouldn't need a new release key going from one dot release to another. However, you can look these up on the Cisco Licensing Portal; click on "Get other licences" and choose "Telepresence Software Release Key" and go from there.
If you can't access the above, then you can also ftp into the system, open "user" folder and you should then see a file called relkeys.v1 which will hold the last three release keys.
/jens
Please rate replies and mark question(s) as 'answered" if applicable.
04-20-2015 10:11 PM
01-26-2018 01:04 PM
if I want to update my 95mxp software from version 9.0.2 to 9.3.4. Do I require licenses? should I reload the keys?
01-26-2018 03:18 PM - edited 01-26-2018 03:21 PM
You do not require a release key. Dot upgrades such as F9.0.x to F9.3.x do not require a release key, a release keys is only needed if you go from one major version to another, ie: F8 to F9. Option keys will remain through the software upgrade, the only time they will be removed is during a factory reset.
Recommend you look into upgrading any older endpoints to newer products available, the MXP endpoints are quite old and full of security vulnerabilities, they software is no longer being supported anymore, and the hardware is soon to not be supported as well, if not already.
01-29-2018 06:09 AM
Patrick:
thanks for your response. just make the update I will comment. Thank you again. regards
01-29-2018 11:44 AM
patrick:
Good afternoon, try to make the update via web and FTP but in both I throw error.
By web throws an error 500 on the website.
By FTP, I followed what the configuration guide indicates, but it also throws a connection error.
I searched for information about the fault and did not find much to solve the problem.
attach images of the errors.
I would really appreciate it if you could help me.
01-29-2018 11:51 AM
01-29-2018 05:26 PM
As @Patrick Sparkman said, it appears you are trying to install the "No Encryption" version on an endpoint that is currently running the "With Encryption" version.
You can check this by doing an "xstatus systemunit software name" command via the CLI. This will tell you the correct software load, which, being the "With Encryption" verison, should show as follows:
xstatus systemunit software name *s SystemUnit: Software: Name: "s50000" *s/end OK
So, you will need to download and install the s50000f9_3_4.pkg.
01-30-2018 05:58 AM
estimated: try to install the version indicated s50000f9_3_4.pkg and I throw the same error via web and ftp.
01-30-2018 04:04 PM
It could be that the internal flash in the endpoint has become faulty. You'd need to arrange an RMA with TAC under a service contract to get that fixed.
If you don't have a service contract, it may not be worth renewing an expired one at this point in time as the MXPs go completely end of support in a couple of months time. It may be a better idea to replace the endpoint with a newer device.
