11-09-2015 07:21 AM - last edited on 03-25-2019 09:14 PM by ciscomoderator
I have received a replacement Blade MSE 8510 from Cisco and "DEBUG" mode seems to be enabled but I cannot find how I can disable this feature. Can anybody help? Thanks
11-09-2015 07:49 AM
Check: Logs > Event capture filter, and make sure everything is set to "Errors, warnings and information". There is a set all option at the very bottom of the page. If that doesn't resolve it, let us know more information what appears to be set to debug and possibly provide a screenshot.
11-09-2015 08:04 AM
Hi Patrick
My logs/event capture is set to errors, warnings and information. There are three things that I see that I cannot seem to be able to disable. (Please understand my screenshots are in french)
1 - Shows the word "DEBUG" on the top right corner of the web interface (see attached picture)
2 - Extra parameters for DEBUG in SETTINGS (see attached picture)
3 - under LOGS/FEEDBACK RECEIVERS I get alot of info I don't have on my other blades (see attached picture)
11-09-2015 08:05 AM
Hi Steve,
Could you contact me at jahodgso@cisco.com please? I'll need to join a WebEx session with you to disable this.
James
11-09-2015 08:09 AM
