Highlighted
Beginner
Ex 90 power supply cell blue LED flashing
Hi folks,
Got 2 Ex90  no powering ON with the power supply blue LED flashing... looked at the PDF but there is no definition for this...
thx
Everyone's tags (3)
5 REPLIES 5
Highlighted
Beginner
Re: Ex 90 power supply cell blue LED flashing
Try change the power supply.
Highlighted
Hi,  I have the same problem
I have the same problem with an EX90. I tried 3 different power supplies but the issue remains. The blue LED is constant blue until I plug it into the EX90, then it faintly blinks. Any other suggestions
Highlighted
Beginner
We ended up changing power
We ended up changing power supplies or sending the unit back to cisco for Reburbished.
Bad batch i guess. I would suggest to check with your reseller if you have a couple of those they might be able to talk to cisco and set you a deal for the repair which will be cheaper than buying new codecs.
The transformers are bad on the power brick.  I've had to replace a couple myself.
Highlighted
Beginner
This blinking light on the PSU means that this PSU is faulty. Please open a case with TAC to proceed with the replacement. Some other cases get solved after this replacement.
Cisco TAC
