EX60 VLAN settings issue TC6.2?
I have a new EX60 running TC6.2 and my computer connected to the EX60 was not able to get an IP from the DHCP pool.  Setting in the network portion of the EX60 were Auto and 1 for VLAN, same as my other EX60s, but I could only get my PC to work when I downgraded the EX60 to TC5.1.8.
Is there a problem here that has already been identified?
DArren
Everyone's tags (3)
5 REPLIES 5
Highlighted
VIP Advisor
You might be bumping up against bug CSCug06492.
"A switch is configured with a default data VLAN on a switch port. It tags all packets, also EAP packets with the DATA VLAN. When xConfiguration Network 1 VLAN Voice Mode is set to Off we can read this packet even though it is tagged with VLAN. When we set VLAN mode to auto or manual we discard any packet that is not tagged with our VLAN".
Does your PC work when you set the VLAN Voice Mode to "OFF"?
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Highlighted
Wayne, do you know if this has been corrected in 6.3?  I just read the bug info, and it doesn't mention it is fixed... unless I missed something on that page.
Highlighted
VIP Advisor
Hi Darren,
Looking at the bug, it's still a known issue with TC6.3.  Fingers crossed it'll be fixed in TC7 due out hopefully later this month.
Did setting the VLAN Voide Mode to "OFF" help with your problem?
Wayne
Wayne
Highlighted
Although your suggestion would have got the endpoint communicating, I needed to have the VLAN voice mode set to on so the PC on the desk would work, too.  I have left the unit at TC5.1until this is resolved.
Thanks.
Darren
Highlighted
VIP Advisor
I guess the other option (if you have enough cabling and switch ports) is to not daisy-chain the PC through he EX, and have both on seperate ports.  This is the way we prefer to do it here as it solves the issue of the PC losing connectivity if the EX is rebooted for any reason.
Wayne
Wayne
