2574
Highlighted
Rising star
Re: EX90 Registered to Regional CUCM :: Not able to dial out of
Yes, go ahead and open a TAC case. To speed up the process, you can open a TAC from this discussion, so TAC team will start your case first checking all the troubleshooting steps we have done until now, so you can save time and avoid re-test.
Paulo Souza
Please rate replies and mark question as "answered" if applicable.
Paulo Souza Was my response helpful? Please rate useful replies and remember to mark any solved questions as "answered".
Highlighted
Beginner
Hi Brandon
I have the same problem with CUCM 9.1 and TC 6.2.  What was the resolution for the TAC case you raised?
Cheers
Trevyn
Highlighted
Enthusiast
tunderhi
Go to >> CUCM Administration >> System >> Enterprise Parameters Configuration >> Set your >> "Organization Top Level Domain".  I believe that alone with fix the issue.  If not, set as well, "Cluster Fully Qualified Domain Name".  Please post if this works for you.
Highlighted
Beginner
Hi Brandon
Thanks for your reply.  I already had the customer's domain set in the Enterprise Params top domain and cluster domain name.  The fix was setting the endpoints to use the 'Standard SIP Profile For TelePresence Conferencing' which has the checkbox ticked for '
Cheers
Trevyn
