Walkthrough Wednesdays
1874
expressway E public CA with godaddy
hi guys,
I just signed expressway E cert with godaddy. during the download of the cert from godaddy it asks for server type.  the types are IIS, exchange, tomcat, other and few more (see attached).  I am not sure which one I should download. any one has any thoughts?
thanks
vijay
1 ACCEPTED SOLUTION
Elias Sevilla Duarte
IIS is normally used for web servers, in the other hand Tomcat is used for added encryption security using TLS, so I recommend using Tomcat.
5 REPLIES 5
Alok Jaiswal
Enthusiast
You can use tomcat, because expressway use tomcat. Though i guess if you download as IIS you would still be able to apply that on the expressway.
Alok
I have used IIS before and it works fine.
Raaj
thank you guys. I will try the tomcat and let you know if anything.
vijay
Hi Elias,
Why do you think tomcat is for TLS and not SSL ?
CUCM, Expressway all uses apache tomcat as web server.
Alok
Content for Community-Ad
Spotlight Awards 2021
