Fail to downgrade MXP from F9.3.1 to F9.1.2
Hi all,
We tried to downgrade our Edge95 and 880 MXP from F9.3.1 to F9.1.2 several times, but all of them had failed.
However we could downgrade them from F9.3.1 to F9.0.1 without any problem.
Then we could upgrade them from F9.0.1 to F9.1.2.
Does anybody know whether this is expected behavior?
Best Regards,
Kotaro Hashimoto
Ravi Yadav
Level 4
Level 4
Hi Kotaro,
Yes that is coming out to be a buggy behaviour as that was encountered on fee devices. We are working on this to see if that can be declared as a bug or that is expected.
Most probably it should be treated as a bug.
Reagrds
Ravi kr.
Sent from Cisco Technical Support Android App
5 Replies 5
Ravi Yadav
Level 4
Level 4
Hi Kotaro,
Reagrds
Ravi kr.
Hi Ravi, Teck,
Thank you for your information.
Unfortunately, I do not have authorization to see detail of CSCuf04817 on Bug Search Tool.
Could you please paste the detail of the bug here?
Best Regards,
Kotaro Hashimoto
Hi Kotaro,
as of now the issue is still in testing and does not have much information .
you can alsways refer to the same bug in furture on you can contact here.
Once the Bug will be posted externally you will be able to view it on cisco.com.
Meanwhile : you already have the workaround .
Ravi Kr.
Hi Ravi,
OK, then I wait for the bug information to be open!
Best Regards,
Kotaro Hashimoto
