05-10-2012 04:47 PM - edited 03-17-2019 11:09 PM
I have my analog phones under the control of CME but when i try to press the **5 to pickup a call I get a fast busy the first time i press the * prefix. Any ideas why this is ? Parts for config below
stcapp ccm-group 1
stcapp security trustpoint SJS253-cme
stcapp security mode encrypted
stcapp
stcapp feature access-code
stcapp supplementary-services
port 1/0/0
fallback-dn 3328
port 1/0/1
fallback-dn 2001
port 1/0/2
fallback-dn 2002
port 1/0/3
fallback-dn 2003
port 1/0/4
fallback-dn 2004
port 1/0/5
fallback-dn 2999
stcapp call-control mode feature
sccp local GigabitEthernet0/0.100
sccp ccm 10.30.58.62 identifier 1 version 7.0 trustpoint SJS253-cme
sccp
sccp ccm group 1
associate ccm 1 priority 1
signaling dscp cs5
telephony-service
secure-signaling trustpoint SJS253-cme
tftp-server-credentials trustpoint SJS253-cme
server-security-mode secure
device-security-mode encrypted
no auto-reg-ephone
authentication credential cisco cisco
max-ephones 58
max-dn 300
ip source-address 10.30.58.62 port 2000
ip qos dscp cs5 signal
service phone garp 0
service phone spanToPCPort 1
service phone webAccess 1
system message Whiting Field
cnf-file location flash:
cnf-file perphone
load 7915-12 B015-1-0-3
load 7915-24 B015-1-0-3
load 7942 SCCP42.8-5-3S
load 7962 SCCP42.8-5-3S
time-zone 8
voicemail 7800
max-conferences 8 gain -6
call-forward pattern ..........
moh flash:music-on-hold.au
multicast moh 239.30.13.1 port 2000
web admin system name cisco password cisco
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern ....
fac standard
create cnf-files version-stamp Jan 01 2002 00:00:00
05-10-2012 07:20 PM
Does it works with no encryption ?
05-10-2012 08:04 PM
I tried taking off the analog phones the encryption and was still getting a fast busy using the analog phones, one thing did i notice is if i put in the command call-park system application under telephony-service i didn't get the fast busy pressing the prefix that was alittle weird to me
05-11-2012 09:55 PM
I don't think is weird because that command changes the way certain things work, so it may be required.
11-21-2012 01:02 AM
I have the same problem.
From analog phone I try to pickup call, but when I begin to dial feature access code, I get busy tone after first "*".
Please help.
Here is my config
Router#sh run
Building configuration...
Current configuration : 16130 bytes
! Last configuration change at 14:55:09 MSK Sun Nov 18 2012
! NVRAM config last updated at 14:53:13 MSK Sun Nov 18 2012
version 15.1
service password-encryption
hostname Router
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.151-3.T.bin
boot-end-marker
card type e1 0 0
logging userinfo
no aaa new-model
clock timezone MSK 4 0
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
no ipv6 cef
ip source-route
ip cef
ip dhcp pool voice_phones
network 192.168.232.0 255.255.255.0
default-router 192.168.232.1
option 150 ip 192.168.232.1
lease 0 12
no ip domain lookup
ip domain name xxxxxxx
login on-failure log
login on-success log
stcapp ccm-group 1
stcapp
prefix ##
port 1/0/2
fallback-dn 380
port 1/0/3
fallback-dn 101
port 1/0/5
fallback-dn 100
isdn switch-type primary-5ess
crypto pki trustpoint TP-self-signed-800503029
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-800503029
revocation-check none
crypto pki certificate chain TP-self-signed-800503029
certificate self-signed 01
30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 38303035 30333032 39301E17 0D313230 39303531 31323431
325A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3830 30353033
30323930 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
DDF6FAB1 1C4897EC CAFB322F 71BC5AA5 A34861FB EF5E2326 11FF1B22 514B0067
52E07A03 E190EC78 49B77E9F 16093441 9786CDC6 42362313 E332E527 E84E87AA
8CFAAAF3 0938C05F 2B9CBFAE 1B4ACF2E 03E4345A C8266C38 2F99DBBE 6678098E
9B9DAF44 5BE94826 36FBC85C 56480DF5 B7B0F272 12449762 9F06AEC5 D239A30D
02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
23041830 1680140C AA1D99BA 9B1A5AB4 F8564475 BB10E3EC 87AEFC30 1D060355
1D0E0416 04140CAA 1D99BA9B 1A5AB4F8 564475BB 10E3EC87 AEFC300D 06092A86
4886F70D 01010405 00038181 003527F1 EC2674A6 629F5FF2 3D10CB3C 5DB18F24
1974E575 BDF6047F 42F8E3CA EFE8E07F 17D04409 315B84B4 5D3E7A6A C07BCD00
118DD252 4953AD42 03BC6C19 7E9CD797 422F6468 94CEAD80 C1BE23D2 396E7A5E
D133807E D6CBAC1B 854B8C9B 25F3FFAF 86B5B1B5 97A1F186 E870B575 1AA334FA
A437BF9D E603B598 6965E8EC E4
quit
voice-card 0
voice service pots
fax rate disable
voice service voip
allow-connections sip to sip
fax protocol none
h323
call start slow
modem relay nse codec g711alaw gw-controlled
sip
registrar server expires max 3600 min 3600
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729br8
voice translation-rule 1
rule 1 /xxxxxxxxxx/ /yyy/
rule 2 /xxxxxxxxxx/ /yyy/
rule 3 /xxxxxxxxxx/ /yyy/
rule 4 /xxxxxxxxxx/ /yyy/
rule 5 /xxxxxxxxxx/ /yyy/
rule 6 /xxxxxxxxxx/ /yyy/
rule 7 /xxxxxxxxxx/ /yyy/
voice translation-rule 2
rule 1 /yyy/ /xxxxxxxxxx/
rule 2 /yyy/ /xxxxxxxxxx/
rule 3 /yyy/ /xxxxxxxxxx/
rule 4 /yyy/ /xxxxxxxxxx/
rule 5 /yyy/ /xxxxxxxxxx/
rule 7 /yyy/ /xxxxxxxxxx/
rule 8 /yyy/ /xxxxxxxxxx/
rule 9 /yyy/ /xxxxxxxxxx/
voice translation-profile outgoing_calls
translate calling 2
voice translation-profile tr_profile_1
translate called 1
application
service ivr flash:try21.tcl
param max-extension-length 3
param reception-number 276
license udi pid CISCO2921/K9 sn FCZ1627203M
license accept end user agreement
license boot module c2900 technology-package securityk9
license boot module c2900 technology-package uck9
hw-module pvdm 0/0
archive
log config
logging enable
notify syslog contenttype plaintext
hidekeys
path xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
time-period 34000
redundancy
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-20
ip ftp source-interface GigabitEthernet0/0
ip ssh version 2
translation-rule 2
Rule 1 yyy xxxxxxxxxx
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp key XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
crypto isakmp fragmentation
crypto isakmp keepalive 10
crypto ipsec transform-set main_3des esp-3des esp-sha-hmac
crypto map main_vpn local-address GigabitEthernet0/0
crypto map main_vpn 10 ipsec-isakmp
12-03-2012 02:53 PM
I dont know if you've gotten this fixed yet but what worked for me was getting rid of the station-id number under the voice port.
ex. I had this, and was happing the problem
voice-port 2/0/12
timeouts ringing infinity
timing hookflash-in 600 150
station-id name Register 7
station-id number 2207
caller-id enable
and changed it to this, and the problem went away
voice-port 2/0/12
caller-id enable
I even opened a TAC case about this and we both worked on this for days and once we went line by line it seemed as if having the station-id number the same as the any number on your ephone-dn caused the problem. I dont know if this will work for you but give it a try
12-13-2012 05:10 AM
Thanks for this info. I will try this and write feedback.
