Have a Codian ISDN 3241 issue
jkozlov
Trying to dial out but continue to get this in the log:
2760820  07:34:48.888   H.323  Info  New connection accepted from 10.1.1.17
2760821  07:34:48.888   CONNECTION  Info  Accepting incoming IP to ISDN call
2760822  07:34:48.967   CONNECTION  Info  6900i6901a: placing partner call as H.320 to "12154899160" (BONDING)
2760823  07:34:49.060   CONNECTION  Info  6900i6901a: cm_ensure_participant_disconnecting... 1
2760824  07:34:49.075   CONNECTION  Info  6900I6902b: cm_ensure_participant_disconnecting... 4
Can someone help me out with this?
trying to work with Vendor but not getting much help
JB
luchand
I think you need to turn on some extra tracing in order to see the Q.931 negotiation - setting the event log capture filter for 'ISDN' to 'Errors, warnings, information and trace' should do this. However, the log will print out the hex codes that correspond to the Q.931 signalling, so it may not mean much unless you have a copy of the q.931 specification to hand - even then it isn't much fun, but we should be able to figure out how far the call is getting and if/why the network is rejecting the call. However, it may be easier raise a case with the TAC team so that they can assist you with this analysis.
It would be interesting to know if incoming calls work at all, and if this has ever worked and has just stopped, or if this is a new installation you're setting up for the first time?
Luc
