Walkthrough Wednesdays
525
RICHARD MESSINGER
Rising star
HDMI Cable Distance Guide
I have been looking through the web site to find a document that would provide guidance on HDMI supportable distances for connecting the different cameras to the Room Kits.  The only thing i am seing is the two 1.5 and 3 meter cables that you can purchase with the kits.
Looking for design limits for HDMI 2.0 cables for the 4K cameras and monitors to be supported.
Any thoughts or pointed urls?
1 ACCEPTED SOLUTION
RICHARD MESSINGER
Rising star
Finally found Cisco Link for the Max distance that the Quad Camera can be away from the codec 9 Meters/30 ft.
https://projectworkplace.cisco.com/en-us/devices/cameras?action=0
4 REPLIES 4
Jaime Valencia
Hall of Fame Cisco Employee
Wayne DeNardi
VIP Advisor
For 4K on standard cables - 3 metres (10 feet) is the recommended maximum.
If you want to go further, you will need to use boosted/repeater cables.
The 8m presentation cable (CAB-PRES-2HDMI-GR) that comes with the RoomKit codec is an example of a boosted cable - note these are usually directional as well to add to your installation headaches.  Get them around the wrong way and they won't work.
We use some active optical cables here to get up to 20m - but these don't come cheap.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
RICHARD MESSINGER
Rising star
garryemiller
Beginner
Use SCT camera extenders kits for distance over CAT6 cable
https://www.soundcontrol.net/
Content for Community-Ad
Spotlight Awards 2021
