887
gavin han
Beginner
help in regards to regex for vsc
I need some help with regex.
1) any pattern that starts with 15 and if it is 12 to 15 digit long (including 1st digits 15) than consider it as a good match and then send the call to destination zone
2) any pattern that meets requirements in (1) but if it has "@domain.com" than take out "@domain.com" from the pattern and send that 12 to 15 digit pattern to destination zone.
3) any incoming call that is valid URL or DN i.e. if url is sip:2xxxyyyy@domain.com or h323:xxxyyyzzzz than consider it as a valid URI or DN and send it to the destination zone.
what would be regex to accomplish requirements in 1,2,3.
I'm kinda new to regex. is there a good tutorial for regex with examples.
Thanks all for your help.
2 REPLIES 2
gubadman
Participant
you can do 1 and 2 with something along the lines of:
regex: (15\d{10,13})(@domain\.com)?
replacement: \1
this is 15 follow by min10, max 13 more digits with optional domain.com (the . between domain and com is escaped as . is a special character in regular expressions)
then the replacement is just the first capture group and not the second capture group so if there is a domain.com it's removed.
This is a good reference - http://www.regular-expressions.info/reference.html
awinter2
Rising star
Gavin,
there are many great regex references online, one of them being http://www.cheatography.com/davechild/cheat-sheets/regular-expressions/.
The 'Check pattern' tool (Maintenace > Tools > Check pattern) on the VCS itself is also a great tool for validating regular expressions for making sure that regex expressions work the way you intended them to.
Now regarding the specific patterns you requested, I'll give it a go (These come without warranty ):
1)
Pattern string: 15\d{10,13}
Pattern behavior: Leave
2)
Pattern string: (15\d{10,13})(@domain\.com)?
Pattern behavior: Replace
Replace string: \1
3) The following regex would match a called alias which is either a URI (something@domain.tld) or a DN entirely consisting of digits. Please note that the '.' regex matches any character except newline:
((.+@.+\..+)|(\d+))
The above regex is not very strict in terms of the URL part, it will match
1 or more characters followed by an @-symbol followed by 1 or more characters followed by a punctuation followed by 1 or more characters.
Hope this helps you on the way
- Andreas
Create
Recognize Your Peers
Content for Community-Ad
