Help ... sip account for sx20
I need help.... how can setting sip account for sx20 ( i have to create account too) Thankssssss
Martin Koch
It also depends on which software you run on the sx20 and where you want to register it to and
how the setup of your registrar/network looks like.
So without that:
Configure the sip settings accorting to the admin guide :-)
Tomonori Taniguchi
SX20 support standard SIP and able to register multiple vendors SIP server (Standard, UCM, Alcatel, Avaya, Nortel, etc.).
Of course best and feature rich will be by using either VCS or UCM as SIP server.
For example, by minimum (while use VCS as SIP proxy server)
(configuration sample by using API, but you may configure same from Web GUI as well.)
  • Enable SIP mode, xConfiguration NetworkServices SIP Mode: On
  • Configure SIP URL, xConfiguration SIP Profile 1 URI: 777@mydomain.com
  • Configure SIP server type, xConfiguration SIP Profile 1 Type: Standard
  • Configure SIP proxy server address, xConfiguration SIP Profile 1 Proxy 1 Address: "192.168.1.100"
  • Configure SIP proxy discovery method, xConfiguration SIP Profile 1 Proxy 1 Discovery: Manual
