01-31-2012 12:27 AM - edited 03-17-2019 10:46 PM
Hi. I'm a junior engineer in South Korea.
I am managing the IPC 4500E with DMP 4310 recently.
I want to show IPC 4500E's view on the LCD connected with DMP 4310, 4400.
Multicast setting is ok on same network. I already tested on DMP4310, 4400 with media Server. It worked.
I can see the movies on the LCD with DMP and Media Server.
but It dosen't work when I connect ICP-4500 to DMP.
when I checked the packets through the Wire-Shark, I can find the multicast packets.
I changed many setting values, such codec(H.264, Mjpeg), Port number, address, enable channel, protocols etc...
But DMP cannot play any streams... why? I don't know more...
I hope your kindness... thanks to read this bad writting.
P.S I know there is cheat to show camera's view with session hijaking through click view video page on the IPC-4500E's web maintain page.
but I need multicast system to this site...
real environment : doesn't work on both multicast and unicast. worked with media server with cat 4500 and DMPs
IPC - 4500E ------------------------ Cat4500 switch -------------------- DMP 4310, 4400 with LCD
test environment : only session hijaking is working on VLC player, reached the multicast packets but unable to notice & play on VLC player.
IPC - 4500E -------------------- PC(VLC Player)
* references detailed config posted jpg file
02-23-2012 04:25 AM
I have the same problem. I'm trying to play a video stream from Cisco IP Camera 2500 to DMP4310 or 4400 but not work.
Any idea???
02-23-2012 03:12 PM
Sorry, no one answer yet..
I have no idea;;
