Highlighted
Beginner
How does on premisse Telepresence integrates with Webex Cloud
Hi all,
I've been wondering how does Telepresence systems integrates with Cisco Webex cloud?
What are the components needed to set it all up?
Does the endpoints still register directly to CUCM as they would and uses Expressways as B2B to reach the cloud?
Thanks for responses
3 REPLIES 3
Highlighted
Please go through the link below:
http://www.cisco.com/c/en/us/td/docs/telepresence/infrastructure/tms/config_guide/webex_enabled_telepresence/cts_webex_config/cts_webex_tms.html
Aseem
Highlighted
Beginner
Hi Aseem,
Hi Aseem,
Thanks for your reply.
So that means that you DO have to have TMS and an MCU?
What about the VCSs/Expressways, do they fit into the whole deployment?
Just thinking on a high level overview so I can understand it better.
Highlighted
The link Aseem provided is
The link Aseem provided is for a Hybrid solution, where you host the conferences on your on-premise hardware.  If you have the CMR Cloud feature, WebEx will then host the conference in the cloud, see CMR Cloud Enterprise Deployment Guide (WBS31).
Content for Community-Ad
Future of Work Virtual Summit Day 5
Cisco COVID-19 Survey
