07-12-2019 03:45 AM
How to Connect Cisco Table Microphone 20 and DX80??
Dx80 Have only one USB Port ?
Any Solution?
07-12-2019 11:46 AM
07-14-2019 11:43 PM
In short - you can't. The DX80 is not designed to have one of the table microphones connected.
If you need to use external microhones, then your best option is to use a bluetooth device that supports the HFP (Hands-Free Profile) or A2DP (Advanced Audio Distribution Profie).
If you're getting to the stage where you are moving that far away from the device that the internal mics are unable to pick you up clearly, then you are probably better off using a different model endpoint than fiddling around trying to make the DX work (such as the Room Kit series).
