04-29-2020 12:43 AM
Hello Guys
I have the following amount of licenses for expressway C and E but I don't know exactly how many I have to add for each one
4 LIC-SW-EXP-K9
1 LIC-EXP-E-PAK
2 LIC-EXP-ROOM FOR EXP-E
2 LIC-EXP-E FOR EXP-E
2 LIC-EXP-TURN FOR EXP-E
4 LIC-EXP-SERIES FOR EXP-E AND C
2 LIC-EXP-AN FOR EXP-E
4 LIC-EXP-GW FOR EXP-E AND C
110 LIC-EXP-DSK FOR EXP-E
My questions are how many liceses do i have to add to each expressway? for example the 4 LIC-EXP-SERIES do i have to add 2 for Expressway C and 2 for Expressway E and the same for 4 LIC-EXP-GW 2 for Expressway C and 2 for Expressway E?
The rest of licenses for Expressway E where there are 2 of each one should I have to add 2 of the each licenses or just 1? and I suposse I have to add the 110 LiIC-EXP-DSK for Expressway E?
04-29-2020 08:38 PM
04-29-2020 10:28 PM - edited 04-29-2020 11:10 PM
It might help if you start by telling what you intend to use the Expressway system for? To mention a few use cases there is MRA, B2B, device registration (VCS), Webex hybrid services. Which one are you intending to use?
04-29-2020 10:29 PM
Hi ,
refer the link for clarity.
regds,
aman
05-13-2020 07:23 AM
@mdrangell22here is the breakdown of the usage.
The expressway series just turn the server from VCS (default) to actual Expressway series. VCS is no longer used so you need 1 license per expressway server you installed.
Are you allowing endpoints to register to your expressways? Can you provide more details on how you want your expressways to operate?
PID | Description | Where to Apply |
LIC-SW-EXP-K9 | Release key for Expressway – This is the main release key for the VM | Both |
LIC-EXP-SERIES | Enable Expressway Series Feature Set – Turns a VCS Series into an Expressway Series | Both |
LIC-EXP-MSFT | Microsoft Interoperability Option – For LYNC integration | Exp-C |
LIC-EXP-GW | Enable GW Feature (H323-SIP) – For H323-SIP interworking | Exp-C |
LIC-EXP-RMS | Expressway Rich Media Session – For specific calls like B2B and LYNC integration | Exp-E for B2B and Jabber Guest Exp-C for interoperability gateway |
LIC-EXP-TURN | Enable TURN Relay Option – For enabling TURN feature which is used for Jabber Guest | Exp-E only |
LIC-EXP-AN | Enable Advanced Networking Option – Enable Dual-NIC and Static NAT address | Exp-E only |
LIC-EXP-E | Enable Expressway-E Feature Set – Turns an Expressway-Core into an Expressway-Edge | Exp-E only |
LIC-EXP-ROOM/DSK | Enable the registration of Room/Desk endpoints to the Expressway-C. Remote devices are proxied to Expressway-C by Expressway-E. | Exp-C only |
