How to remove Macro and In-Room Control via provisioning?
RenzKanwischer
I have a question:
We are using "xCommand Provisioning Service Fetch" for mass provisioning of Macros and In-Room Controls. This works as expected.
Now we have the need for removing some of the previously provisioned Macros and In-Room Controls. Is there a way to "Uninstall" a previous bundle or to remove Controls and Macros separately?
Renz
Magnus Ohm
Hi, you are provisioning the macros using a bundle, this is a backup restore procedure. To remove the individual macros you need to issue an xCommand on each codec. This can be provisioned via TMS (not UCM) as a custom command or you can script it (using the SSH xAPI or XMLAPI. You cannot provision custom commands using the backup and restore mechanism.
The command you should use is:
xCommand Macros Macro Remove Name: nameofmacro
I do have a script to send custom commands via the XMLAPI using a CSV file of codecs, let me know if you need it. If you have your own solution thats fine as well. :)
/Magnus
6 Replies 6
Magnus Ohm
/Magnus
Hi Magnus,
thanks. I think this would work here as well. Can you send me the script you mentioned, please?
Renz
Is there a way to remove In-room control panels as well?
xujf
I am very interested in using "xCommand Provisioning Service Fetch" for mass provisioning of Macros and In-Room Controls.  Could you share me how to do it?
I use the command to update the provision, but it failed
xCommand Provisioning Service Fetch Checksum:"7b6a91e2fd68729dafc06450ddab032ff9a6eec1b4aac9828a2d1bde9af309f4f5dac11965bf90636f7958a042e78d27ac95f49ac935f8b240dd0692fb45906c" ChecksumType:SHA512 Mode:Replace Origin:Other URL:"http://bbtms.1table.cn/tms/public/external/management/systemmanagementservice.asmx"
OK
*r ServiceFetchResult (status=Error):
*r ServiceFetchResult Reason: "Checksum mismatch"
** end
espholmb
The file you should be pointing to should be the backup.zip file created when you created a backup from the web page of the system, and not the tms provisioning file.
bolguin01
Hello All,
Has anyone figured out how to remove In Room Controls in bulk?
Thanks!
