1894
Seeker
Beginner
How to use xAPI for SX10
I was able to create a few macros for endpoints that can support the macros naively with some of the code in previous posts, however I would like to get my SX10 using similar macros such as quick dial..etc. I understand this can be dove via an xAPI however I am not sure where to start testing and how to deploy.
Thank you in advance,
-S
1 ACCEPTED SOLUTION
JFerello
Beginner
The SX10 does not support macros, it is not powerful enough.
Justin Ferello
5 REPLIES 5
JFerello
Beginner
Justin Ferello
I currently have a macro to quick dial different webex domains on supported devices, how do I replicate this on SX10 via xAPI?
You can add the WebEx IVR (meet@<sitename>.webex.com) as a favorite on the SX10, then users can dial it from the directory and when prompted by the IVR, enter the meeting ID.
Is there any workaround or any other alternative we can use the Macros on SX10?
Do you find an afordable solution for that? It would be nice to also have macros on that device. I can't understand why that isn't powerful enough for simple tasks. Or just the ability to have start scripts like the old C endpoints would be nice.
Thx, best Regards
Thiago
Create
Recognize Your Peers
Content for Community-Ad
