2431
Eli Kagan
Beginner
ICE configuration
My question is about best practices when it comes to enabling ICE. Cisco documentation is really lacking in this department.
I have a straightforward design: VCS-E in the DMZ, VCS-C on the inside, with endpoints and MOVI connecting both on the inside (internal users) and outside (home users behind their home firewalls). VCS-E has TURN enabled.
Home users ----  Internet  ------- FW ------ VCS-C -----local users
                              VCS Expressway
The question is what's is the right way to set up ICE to provide best media routing for all users?
As far as enabling ICE on VCS-E, which zones do need ICE enabled? Default Zone, DefaultSubzone, DNS Zone?  Do I need to enable ICE on the TraversalZone to the VCS-C?
Do I need to enable ICE on VCS-C at all and if so on which zones?
What should I set Default Media Candidate and Public Media Candidate for MOVI users?  Is it Host and Relay respectively?
Same question for C20 Endpoints.  Should I set it to Relay for external endpoints and turn ICE off for internal endpoints?
Any enlightenment would be appreciated.
Eli
2 REPLIES 2
mmihalyf
Hi @Eli Kagan ,
What was your finding?
I'm looking for recommendation on best setting for source to be Host or Relay?
Sorry, can't recall now. It was six years ago......
Create
Recognize Your Peers
Content for Community-Ad
