Installation problem of TE6.0.2
shun19830527
I'm trying to install TE6.0.2 on EX60, however the installation gets stuck when it's proceeding...
The circumstance I have is as below.
CUCM version: 9.1.1.10000-11
Previous SW version: TC5.1.4.295090
New SW version: cmterm-ex-te6_0_2.cop.sgn
The procedures I took are
- upload software on CUCM
- change device default setting of EX60
- restart TFTP server function
- restart EX60
I could see EX60 was registered on CUCM but couldn't use web interface...
Also, I tried to install the beta version of TE6.0.2, it's succeeded...
Do I miss something to install TE6.0.2 ?
Thank you in advance !
thobonho
Hi Shunsuke, not sure where you got this version but latest software release for EX60 is TC6.0.1 :
http://software.cisco.com/download/release.html?mdfid=283645052&catid=280789323&softwareid=280886992&release=TC6.0.1&relind=AVAILABLE&rellifecycle=&reltype=latest
Concerning the web access, in CUCM, under Device > Phone > your EX60 > Product Specific Configuration Layout, you should check that Web Access is actually enabled.
Hope that helps!
Hi Thomas / Shunsuke:
TE6.0.2 is a official release for EX60 on CUCM, see:
http://software.cisco.com/download/release.html?&mdfid=283645052&catid=280789323&softwareid=280886992&release=TE6.0.2&rellifecycle=&relind=AVAILABLE&reltype=all
Release notes:
http://www.cisco.com/en/US/docs/telepresence/endpoint/software/te6/release_notes/te_software_release_notes_te6.pdf
Regards what Thomas said, yes, you should check in the provisioning on CUCM if web access is enabled,
I think its disabled by default.
Good success :-)
Thanks for your answer, Thomas and Martin.
Actually, web access is enabled. SSH access is enable as well.
Anythig else I have to concern about ?
Shunsuke
