11-22-2019 08:11 AM
Good day
As there are many manufacturers of mobile phones, I am sure that connecting anyone of them is going to have problems. I have been running integration tests with Samsung S10, S8, and Apple iPhone 8 and an iPad Pro.
In all cases the application used to connect to the VTC is the Grandstream Wave (or GS Wave) application version 1.0.3.29 for the Android device and GS Wave version 1.2.11 (1.2.11.4). Audio connectivity on all devices is excellent. The big issue is Video. Both Apple devices have two way video, although I am sure the video performance needs some tweaking All Samsung devices transmitted video is received, but NO video from the VTC is received. Again this is probably a tweak that this required on the VTC and device settings.
Testing is being performed over a wi-fi network. We understand that performance will be dependent upon the characteristics of the device to VTC connection. All mobile devices are setup as follows:
Vocoder: PCMU, PCMA, G722
H.264 Image Size: VGA
Video Bitrate: 384 kbps
On the VTC:
Presentation channel not not used in this test. For multiple mobile phone access to a conference I selected the VGA as an average resolution. Again, a great deal will depend on the connectivity from the mobile phone locations. One major issue is the display of the remote phone video. I get the impression that each of the viewing ports for a three remote feed will not adjust for the video characteristics for each feed.
Have not been able to locate any guidelines on the Internet to assist us in this project. Can anyone provide some insight?
Solved! Go to Solution.
12-11-2019 10:44 PM
For starters, the software version you are running is ancient and subject to many security vulnerabilities. TCNC5.1.3 was released back in June 2012. The current (October 2019) software release for the C60 is TC7.3.19.
I'd highly recommend that you update the software on your endpoint.
Also, if you are not already aware, the Profile/C60 reach their end of support date on 31 March 2020, so they shouldn't be seen as a good long term solution, and other more recent endpoint models should be considered in the future (ie Cisco Webex Room series).
Please remember to mark helpful responses and to set your question as answered if appropriate.
12-11-2019 10:44 PM
