10-25-2015 07:35 PM - edited 03-18-2019 05:08 AM
I want to deploy the Polycom MCU to integrate with registered Cisco VC endpoint on CUCM through VCS / Expressway.
** Call the Polycom MCU room address: 192.168.1.11##7777 (Polycom IP: 192.168.1.1 | MCU room: 7777)
Method 1: Polycom MCU registered the SIP & H323 to VCS | registered VC endpoint to VCS > call the Local zone and Subzone membership to enter the Polycom MCU room (But it cannot accept the ## symbols to call )
Method 2:VC endpoints registered to CUCM call the 192*168*1*11**7777 through Expressway (Translate the '*' to become IP address dialing as '.' & Translate the '**' to become '##') | Or use the domain calling (7777@polycommcu.com > translate from Expressway 192.168.1.11##7777)
But I tried and the # symbols cannot be route form Expressway, that would showed the '%20%', which is the error as 'is not a matched URI schema'.
Any idea to integrate the Polycom MCU with Cisco Expressway/VCS?
10-26-2015 09:11 AM
## is standard to Polycom, and it won't work with Cisco products, they won't recognize it and don't know what to do when it receives it.
I would think that the Polycom MCU should be able to recognize Annex O dialing, have you tried? What model and software version is the MCU?
10-26-2015 09:23 AM
Do you mean the Polycom MCU use SIP register to VCS/CUCM? Then, how can I call to the Polycom MCU room?
10-26-2015 09:43 AM
Cisco products won't recognize the ## that used by Polycom systems.
If the MCU is registered to your VCS, have you tried to dial into the Polycom MCU using alias@domain, or just the alias?
What is the model and software version of the MCU, you didn't provide it?
10-28-2015 07:54 PM
We are using the 'Polycom rmx 1000' and tested the SIP call to 7777@192.168.1.11, that also is fail, if the Polycom MCU is not register to VCS by SIP
10-28-2015 09:59 PM
You should make a H.323 call to 7777@192.168.1.11, not a SIP call.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
10-30-2015 11:18 AM
As said below, it is important that you understand what you are doing.
Like a friend said: "Impressive, as soon as you do it right it works" ;-)
10-26-2015 03:47 PM
As Patrick has suggested, you should be able to specify the Annex O dial string, so rather than dialing the Polycom format (192.168.1.11##7777), you'd dial 7777@192.168.1.11 on the Cisco equipment.
Wayne
10-26-2015 04:33 PM
If this is your internal enterprise setup I would anyhow look into having a proper number plan as well as URI dialing.
Look at the generic vcs documentation and deployment guides that should give you some thints.
In general you can route for example 7xxx to the MCU, then you would just need to dial
7777 on the endpoint, on h323 it would be a e164 number which then gets properly routed.
On sip it would be suffixed with your sip domain and with the right search rules also hits your MCU.
As this can be a bit complex for the forum I would recommend you ask a local consultant to review your setup.
Some training courses for you might also be handy ;-)
11-02-2018 01:26 PM
Hello, you should dial using protocol h.323 7777##@192.168.1.11
That worked for me from SX10 firmware ce9.3.0 to Polycom MGC-50
06-02-2020 12:19 AM
