1026
soohyung choi
Beginner
Issue with Edge95 and Spark Room kit Plus using H.263 DualVideo (H.239)
When connecting Edge95 and Spark room kit plus codec , Document sharing becomes an issue.(H.239)
In the past discussion I noticed that Edge95 Presentation only uses H.263.
also, in the datasheet I saw that Spark room kit plus codec does not support H.263
If so, Is it impossible to share documents between Edge95 and park room kit plus using H.239?
Thank you for always.
1 ACCEPTED SOLUTION
Rishabh Gupta
HI @soohyung choi,
MXP series endpoints  are very old device and already EOL(End of life  for software development).
https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/telepresence-system-edge-mxp-series/end_of_life_notice_c51-720894.html
On the other hand, Spark Room Series Endpoints are very new units and they do not have support for H.263 or H.261 ,as all the newer products support H.264.
This is mentioned in data sheet for Spark Room Kit Plus : https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/spark-room-kit-series/datasheet-c78-738752.html
Workaround
Use any conference bridge if you want content sharing between these devices.
I have tested with conference bridge (Codian MCU 4520), and could see presentation sharing working correctly.
Rishabh Gupta
2 REPLIES 2
Rishabh Gupta
HI @soohyung choi,
Workaround
Rishabh Gupta
Your answer was very helpful.
I will advise the customer to replace Edge95
Thank you.
Create
Recognize Your Peers
Content for Community-Ad
