Jabber SIP on EX60 Unit
Saeed Halaby
Dears,
i recently downoaded and installed the Jabber Video and it works perfectly on the laptop.
can i transfer the settings, user/pass to the EX60 unit and have that TP unit work with these settings under SIP?
moreover, if the above is possible what should be the SIP address / Proxy?
anyone tested this with EX60 or EX90 and worked?
thanks in advance for your responses,
Saeed Halaby
Martin Koch
No, the free JabberVideo service is offered only for Jabber, but not for endpoints.
If you have multiple endpoints your own VCS might be of interest.
There are services which offer endpoint registrations if you do not want to handle the
infrastructure your self.
The least preferred way you could also run an endpoint on a public ip address or behind nat
withour a registration.
