LOCK DOWN A WEBEX ROOM 55 RUNNING CE9.X.X
Chet Cronin
Level 4
Level 4
Is there a an option to restrict user access from the touch 10 panel for VTC systems registered to the VCS vice the CUCM ???
I have users that want to restrict access to VTC conference room system so only authorized user has the ability to make a call.
If so what is the process ??
Chet Cronin
Wayne DeNardi
By default, NO, but you could remove the default UI buttons and the add a new button to the Touch 10 (with some macros behind it) that requires some form of user input to then enable the default buttons again.  Then upon a call disconnect, you could remove the default UI buttons again.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
