Cisco Community Designated VIP Class of 2020
99
Highlighted
Manual adjustment of the camera speed possible by Cisco Webex Quad Camera?
Hallo,
the camera automatic from the Cisco is turned off...and the call for the camera preset 1-8 is comming from ext. Controller but the camera pan/tilt/zoom function are very fast.
Can we global adjustment the camera pan/tilt/ Zoom slower at the web browser gui?
Best regards,
Torsten
1 REPLY 1
VIP Advisor
Re: Manual adjustment of the camera speed possible by Cisco Webex Quad Camera?
If the camera is being controlled by an external controller, then you would likely need to change the command that it is issuing to the codec/camera.
When issuing an xCommand Camera Ramp command via the API, you can specify the PanSpeed, TiltSpeed and ZoomSpeed.
If you're just triggering Presets, then the camera should just jump from one to the other and the "speed" it changes cannot be altered - it just happens.  As the camera has a 4K sensor, it's capturing the whole scene, the view you are seeing is a digital crop of this, so there is no "movement" between.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Content for Community-Ad
FusionCharts will render here
