MCU 4575 integration with CMS Recording
gawankar_sanket
Dear Expert,
Can we integrate MCU 4575 with CMS acano Recording solution?
I couldnt  find relavant document on this topic.
Your opinion will be grateful.
Patrick Sparkman
You might be able to by cascading the two conference bridges together, have one dial into the other, but this isn't supported and you might get some strange side affects where content or other things might not work correct. The best solution is to use the CMS to host your conference and record it at the sametime.
