Highlighted
Participant
Mgcp voice gateway receice call but not forward local DN number
Hello Everyone,
I want to configure mgcp gateway with Cisco 2921,  I hear one time calling voice and it drop, We have a 5 DID number, and all port assign to DN
Thanks For help,
My config is below,
redundancy
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
controller E1 0/0/1
shutdown
framing NO-CRC4
clock source internal
ip ftp username ftpdestekhiz
ip ftp password 7 01425F570C1F14
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.5.201 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn bchan-number-order ascending
isdn sending-complete
no cdp enable
interface BRI0/1/0
no ip address
isdn switch-type basic-net3
isdn point-to-point-setup
isdn bind-l3 ccm-manager service mgcp
interface BRI0/1/1
no ip address
ip default-gateway 192.168.5.254
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.5.254
ip route 10.10.10.0 255.255.255.0 192.168.1.253
control-plane
voice-port 0/0/0:15
echo-cancel coverage 64
cptone TR
voice-port 1/0/1
supervisory disconnect anytone
no vad
cptone TR
timeouts call-disconnect 5
timeouts wait-release 1
timing hookflash-out 50
timing sup-disconnect 1000
connection plar opx 4061
description TT_Line
caller-id enable
voice-port 1/0/2
no vad
cptone TR
description TT_Line
caller-id enable
voice-port 1/0/3
no vad
cptone TR
description TT_Line
caller-id enable
voice-port 1/1/0
no vad
cptone TR
description TT_Line
caller-id enable
voice-port 1/1/1
no vad
cptone TR
description TT_Line
caller-id enable
voice-port 1/1/2
no vad
cptone TR
description TT_Line
caller-id enable
voice-port 1/1/3
no vad
cptone TR
description TT_Line
caller-id enable
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 192.168.5.200
ccm-manager config
mgcp
mgcp call-agent 192.168.5.200 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp playout fixed 80
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
no mgcp explicit hookstate
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp profile default
dial-peer voice 999020 pots
service mgcpapp
port 0/2/0
dial-peer voice 999022 pots
service mgcpapp
port 0/2/2
dial-peer voice 999021 pots
service mgcpapp
port 0/2/1
dial-peer voice 999030 pots
service mgcpapp
port 0/3/0
dial-peer voice 999031 pots
service mgcpapp
port 0/3/1
dial-peer voice 999032 pots
service mgcpapp
port 0/3/2
dial-peer voice 999033 pots
service mgcpapp
port 0/3/3
dial-peer voice 999023 pots
service mgcpapp
port 0/2/3
dial-peer voice 999100 pots
service mgcpapp
port 1/0/0
dial-peer voice 999101 pots
service mgcpapp
port 1/0/1
dial-peer voice 999102 pots
service mgcpapp
port 1/0/2
dial-peer voice 999103 pots
service mgcpapp
port 1/0/3
dial-peer voice 999110 pots
service mgcpapp
port 1/1/0
dial-peer voice 999111 pots
service mgcpapp
port 1/1/1
dial-peer voice 999112 pots
service mgcpapp
port 1/1/2
dial-peer voice 999113 pots
service mgcpapp
port 1/1/3
dial-peer voice 1 pots
service mgcpapp
direct-inward-dial
port 0/0/0:15
dial-peer voice 2 voip
destination-pattern 4...
session protocol sipv2
session target ipv4:192.168.1.230
dtmf-relay sip-notify h245-alphanumeric
codec g711ulaw
gatekeeper
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input all
scheduler allocate 20000 1000
1 REPLY 1
Hall of Fame Cisco Employee
Is this related to video??? I ask because you're posting this in the Video over IP section.
If not, then please move this to the appropriate area and make sure you post in the right area.
Exactly on which interface are you receiving the calls you talk about??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Content for Community-Ad
August's Community Spotlight Awards
