11-02-2012 10:56 AM - edited 03-18-2019 12:04 AM
Hello all,
How can i give the mic sound to HDMI out on the C 60 at my side and to the other side which is called?
Thank you.
Solved! Go to Solution.
11-02-2012 11:00 AM
Hi Emre,
Have you tried to use Cisco TC Console application ? I would recommend you use that and it would really make it easy for you to make such changes, here's the link of the TC console which you can download and install on your PC:
http://developer.cisco.com/web/telepresence-developer/tools/integrators/tc-console
Hope this helps.
Mubashshir Akhtar
11-02-2012 11:00 AM
Hi Emre,
Hope this helps.
Mubashshir Akhtar
11-03-2012 08:09 PM
Hi Emre,
Any specific reason to play local audio on local monitior ? I suspect it will create ECHO in call.
Kind regards,
Dharmmesh
11-05-2012 02:31 PM
I got the mic sound with TC Console that is make it east, thank you for your help.
11-05-2012 02:44 PM
Hi Emre,
Glad to see that it helped you. Please mark the question as answered since you're issue is resolved.
Mubashshir Akhtar
