10-27-2011 09:09 AM - edited 03-17-2019 10:34 PM
What file do I send to my support group in order for them to "push" the Movi application file to several PCs at one time?
Solved! Go to Solution.
10-28-2011 08:52 AM
This is dependent on what they ask you to send, obvious they need the application itself to distribute it :-)
You did not mention if its windows or macintosh,
anyhow I would send them the link to the Movi4.2 software archive, the release notes and the admin guide:
http://ftp.tandberg.com/pub/software/endpoints/movi/movi4/S85000MCX4_2_0_10318.zip
http://ftp.tandberg.com/pub/software/endpoints/movi/Cisco_TelePresence_Movi_Release_Notes_4-2.pdf
and ask them if they need more.
Depending on your deployment and how much of the config shall be done automatically you might need
to send them more info (like your advanced settings / registry keys for movi) which they might be able to
"push" as well.
Martin
Please vote the replies and set the answer to answered if it is.
10-28-2011 08:52 AM
"push" as well.
Martin
10-28-2011 08:59 AM
Thanks for your answer. We use the .msi file which is included in the .zip file. I was not aware of that. But thanks for your reply anyway.
10-28-2011 02:00 PM
You are welcome! Thank you for voting and have a great weekend!
