01-10-2013 11:59 PM - edited 03-18-2019 12:25 AM
Understand that there is a online calculator tool available to determine the power requirements for your MSE 8000 chassis and blades. The calculator results are in DC power and current.
How do i determine the power and current requirement in AC? Having difficulty understanding and input the values of the rectifier efficiency .
Best Regards,
TF
Solved! Go to Solution.
01-11-2013 12:22 AM
Without the garantee that this info is without failure:
I assume you are using:
I think the Valere power supplies have an efficiancy around 90% like the example value,
guess more inefficiant computer power supplies go down to 70%, that is what the power
supply consumes for itself (in other words to heat the room :-)
Btw, the amount of rectifier modules is what you need to power it up, but to be redundant
you need the double amount, in the example below it shows 2 but it should be 2x2, two for each rack.
So with 1x8050 and 4x8510 and 90% you would get something like:
The results are as follows (values are rounded up):
Requirements | Value |
DC power (Watts) | 1800 |
DC current (Amps) | 38 |
Number of Valere rectifiers | 2 |
Using the rectifier efficiency value that you entered above, the AC power and current results are as follows:
AC power (Watts) | 2000 |
240V P.S.U. current draw (Amps) | 9 |
110V P.S.U. current draw (Amps) | 19 |
01-11-2013 12:22 AM
01-15-2013 07:54 PM
Hi Martin,
Thank you very much for the information.
Best Regards,
Terence Foo
