04-28-2016 10:54 AM - edited 03-18-2019 05:52 AM
Symptom: Calls between an MX300 G2 running CE8.1 and several different TX1310 immersive units would not setup. Conference Control Center showed 'Dialing' but no connection took place.
Solution: Disabling multi-way on the MX300 G2 allowed calls to build properly.
This test is accurate and was reproduced with two distinct TX1310 units.
Architecture:
This would appear to be a bug. TAC, can we pursue this please?
04-29-2016 07:40 AM
As this is a public forum, if you want Cisco to investigate an issue you found and fix a possible bug, you should open a case with TAC directly. This can be done through the forums on the right side of the page under Actions, or from Cisco.com/suppport.
04-29-2016 10:56 AM
I do have a case open and I reported it there as well. In the interest of letting people who might also run into this problem and happen to search the forum (like I did) I wanted to share with the community.
Quick update: after further testing we found today that enabling Multiway also breaking all calls from telepresence systems to the PSTN. I'll report back as I find more information. TAC is still investigating this with me today
