01-15-2016 01:33 PM - edited 03-18-2019 05:26 AM
Anyone that had installed one MX200 G2 with Floor stand Feet could confirm to me that the back cover is like this on picture?
Because i can't close back cover it seems that two male connector are wrong...
01-15-2016 04:23 PM
I've never put one together before, but from what I've seen of them in person, it should all go together nicely. Is there anything that the cover could be hitting on, or in the way?
01-17-2016 08:49 PM
I haven't built a 200, but have done a number of 300s which are the same, just bigger.
Are you lifting the handle to lock/unlock the back cover. You need to hold it up to be able to close it, then it locks back in the down position to hold it closed (Step 6 of the Installation Guide).
If it is still not getting close to being closed, make sure that all the cables are inside the cable guide, and that the cable channel lid is closed securely (Step 4 of the Installation Guide).
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
01-18-2016 03:43 AM
Hi Wayne,
Yes i'm lifting handle.... The question is that in picture that i attach if you saw the red square i think it should be hole (like female connector) instead of that (male connector) because in the top when you lift the handle are (male conector).
01-19-2016 03:51 PM - edited 01-18-2018 06:29 PM
I don't have one easily accessible to check right now. I have another 300G2 being delivered later in the week so can check that one for you when it arrives.
Edit: I checked the MX300G2, and it is slightly different, it does have two holes, rather than the bumps on the top edge (the bottom is opposite). They are also in a different orientation (rotated 90 degress from what you have shown for the 200).
01-18-2018 04:17 AM
