166
Beginner
MX800D Questions
Hi Guys
For the MX800D it's build-in 2 cameras , and one for main camera another for speaker track , if disabled speaker track feature there's one camera working ? is that correct? or 2 camera both are working for video output for other site if we're in video conference.
THX
Harvey
1 ACCEPTED SOLUTION
Enthusiast
Re: MX800D Questions
Speaker Track can cover a room up to ten meters (33') deep, should be no problem with an 18 person table. It does not use both camera images at the same time, it will zoom in on the speakers and show a wide angle shot when nobody is talking. it uses a combination of audio triangulation and facial recognition.
Go to this site for more information and a video that shows how it works.
https://www.cisco.com/c/en/us/products/collaboration-endpoints/telepresence-speaker-track-60/index.html
Hope this helps.
4 REPLIES 4
Enthusiast
Speaker track uses both cameras, the system does not move the active camera. The inactive camera will "find" the next shot and then it switches over to active. There is no speaker track functionality unless both cameras are working.
That said, you can disable it and use presets just like any other two camera system if your use case makes that a better fit.
Highlighted
Beginner
Hi PJMack
Thanks for quick reply , just one question for confirm that the environment of video room is so large and 18 seats there , one camera may not cover the all seats area, need two cameras to be done. my question is the two camera can work together for all seat for video collection and output and transmit to other video room and the other room can be displayed the whole video image of 18 seats by mx800D
THX
Harvey
Enthusiast
Hope this helps.
Beginner
Hi PJMack
Great !! thank you so much. it's so clearly for me
yunzhang
Content for Community-Ad
August's Community Spotlight Awards
