10-20-2013 09:34 PM - edited 03-18-2019 01:59 AM
I need Tandberg MXP 3000 Codec's Power supply adapter.
anyone who know this P/N is there, please help me.
It's hard to find EOS/EOL parts.
regards.
10-20-2013 10:10 PM
If you can't find an exact replacement, any 12V DC / 4.3A power supply should work fine.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
10-20-2013 11:32 PM
If your system still has a valid service contract, then Cisco will supply a replacement for free. Just open a RMA request with TAC - all they need it the s/n of the codec - and you don't have to return the faulty p/s.
Even though it is EOS/EOL, you will still be able to renew service contracts for these up until July 30th 2016. The 3000MXP doesn't become obsolete as far as service/warranty etc goes until May 31st 2017.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
10-20-2013 11:37 PM
Hi Wayne and Jens
Unfortuanatly, I didn't purchased service contract.
so, I can't use TAC services.
thanks. ;-)
10-20-2013 11:50 PM
In that case, I can only echo Waynes comment . Any generic psu with the correct specs will do - however, you can also find some original ones on Ebay.
/jens
10-21-2013 06:32 AM
I believe you can maybe use the PrecisionHD Camera psu. This is untested, but I think it might work from what I recall. As Wayne and Jens points out, just check the specs and voltage first of the psu.
