Need help 'Dis-Abling' EX-60 Bluetooth
coleman6604
I need some help with figuring out how to Dis-able the Bluetooth capability on an EX60 telepresence system.
The unit is new with software Version:  TC6.0.0.876266
I have not found any refernce documents in how to do this.
Thank you,
Charles Coleman
charles.coleman.ctr@pentagon.af.mil
5 Replies 5
Hi Charles,
The Bluetooth feature is only available on the TC 6.1, so you don't need to disable on the version TC 6.0
In the TC 6.1 there isn't any command to disable bluetooth, you can only set the preferred output device by using the command as follows:
Audio  PreferredOutputConnector:
Melquisedeque Gomes
Brazil
Hi Charles,
I agree with Melquisedeque, as far as I know, there is no command to disable bluetooth globally. The user will have the option to whether using bluetooth headset or not, it is a user configuration, so you cannot block it.
But tell something, why would you need to disable it?
Paulo Souza
Please rate replies and mark question as "answered" if applicable.
Paulo Souza Was my response helpful? Please rate useful replies and remember to mark any solved questions as "answered".
Hi Charles,
I have tested with TC 6.2 beta version and found commnad for that.
Welcome to ex 90
TANDBERG Codec Release TC6.2.0 Beta3
SW Release Date: 2013-05-16
xConfiguration Experimental Bluetooth Mode: Off
Kind regards,
Dharmmesh
There can be a couple of reasons why you want to disable it could picture these two are the most common:
* security
* remove unnecessary interference on the 2.4 ghz band
There are even organizations which do not allow to have wirless hardware build in, ...
It makes sense.
Paulo Souza
